1 - 17 of 17 Posts
Could someone tell me if the is something that would bond the metal drive shaft to the plastic collar on a bachmann dd40? It is the plac where the drive shaft, or dogbone if you prefer, meet the worm gear. If you could help me with this I would greatly appreciate it. Thanks in advance.
You don't want to do that! the shaft is meant to move in and out and if you prevent this by gluing then you will get problems with the drive bogie, If the collar has the slots in it and they are fine is it because the pins on each side of the shaft have sheared? I had a plastic shaft that lost the lugs and drilled it to put a small metal pin into place. That was long before CA(super-glue) came on the market but it's still working today, I used a two part epoxy resin glue to bond the dissimilar materials together.
Hey rad...I understand the point you are making. Is it possible you are describing an Athearn loco? I looked at the Bachmann shafts when mine was acting up, and if I remember right, mine had a female collar on the end of one shaft, and a male insert on the end of the other. I don't recall any pin on either shaft, but I have seen them on the Athearn.
For me, the glue made the difference between working and not working.
Chad
Chad
Hi Chad,
I don't doubt for a minute you have yours working but when you use an adhesive on a flexible shaft you no longer have a flexible shaft, I just stripped down one of my Bachmann's and it's got a dog bone shaft(although not metal)
with the pins on each end. Once I know how to upload some pics to a post I'll show them
Hey Rad...that sounds good. I have only had one Bachmann apart, and it was the one I fixed. It was just a cheap $29 loco. I had purchased it 950 miles from home, so taking it back wasn't really that practical. This loco had the setup I described (that's if I remember it right). I don't doubt that some of the higher-end Bachmanns have that dogbone shaft.
I would agree with you that maybe one shouldn't glue a dogbone shaft. Maybe one can get by with it on layouts with large radii, where it doesn't have to turn so sharp.
Thanks for the info!
Chad
Discussion Starter · #10 ·
The collar does indeed have slots where the dogbone inserts. The other end has a simple round hole for the shaft of the worm gear. When responding, keep in mind that I intend on pulling a fair amount of rolling stock.
Hey rad...between you and me, we have cheap covered! He he!
Matt, maybe it was simply defective from the start. If you send it back, I would look for one with a shorter length. My 4-axle GP38's seem to pull as much as the 6-axle trains...maybe more. A six (or more) axle loco will bind in a radius that is too tight. In that case, it would struggle to pull just itself through.
This is just my 2 cents. I looked at a pic of the DD40, and it looks too long to me to go through a 22-inch radius. I wish you the best of luck!
Chad
Discussion Starter · #13 ·
Chad
thanks for the input Chad. This confuses me because I have other dd40's that will go around an 18' radius
Discussion Starter · #15 ·
I don't see where the confusion lies, you already explained that the collars(female connections) were split, This is the reason you have slippage whereas your other ones may still be intact
the confusion lies in someone telling me that a radius of 22 is too small when if seen them operate on my 18 radius just fine.
OK Matt, Are you going to fix yourself? or try to get the new parts, I'm sure you could get in touch with customer care and explain to them the fact that the couplings have split and they should send out some new ones.
Hey there...I apologize for confusion. Let me try to clear some of it up. I am not sure if the problem existed from the start, or if trying to go through the curve caused it to crack. In either case, it sounds like you should take it back. If you were to exchange it for another, I simply thought a shorter wheelbase might work better.
Let me stick with what I DO know. I just bought a Bachmann Spectrum Dash 8. It slows down ever so slightly in my 22-inch radius. Now logic follows that if the DD40 has a longer wheelbase, it would slow down even more. If the trucks turn more on the DD40 to compensate, then you might not want to glue anything, 'cause it would need that flexibility to turn sharper.
I hope everything turns out the way you want. I will check in for follow-up's and see how it is going!
Chad
1 - 17 of 17 Posts
