1 - 16 of 16 Posts
Schizophrenic Engineer
Any thoughts about how much clearance there should be for a bridge going over other rails? What look most realalistic?
John
One simple solution is to adjust the height of the portal and not the bridge. keep the bridge high enough and add scenic sides. They can be removable. Made out of foam, cut to a close tolerance of your highest car/engine.
You can measure(or reasearch) out a real bridge. and convert every 10 feet to 1.4 inches at 1/87 scale
or Buy a portal.
I don't have a number for you just ideas: ohwell:
Discussion Starter #3 (Edited)
This is the aproxament locaton of the bridge. I plan on a hill behind the bridge with a tunnel for the outside track.
I think the paint cans have to go. I am still making the truss part of the bridge. I want to make a trestles to the left, and a hill to the right. both will be new to me.
Any comments welcome.
Sweet:thumbsup:
If you needed to spare the grade a bit, you could easily drop it 3/4". That would make your approaches a much easier grade. That height looks great though, if you can make the grade workable. Them Y6bs like to be treated nice...:D
Discussion Starter #5 (Edited)
Sweet:thumbsup:
Ya, I got my first one for my 12th birthday. I wore it out. I tried to get parts for it and was told that it would never run again. Dame. Years later I went to a model train show and bought another one. I still have the both of them. I want to make a dummy out of the 1st one. Strange that your N & W, and my SOU Y6B have the same number as my first Y6B.:laugh:
I want to get bridge as low as I can so that most of my engines can use this track. I don't want it to look to low.
Yep...musta been a misprint:D...that might be one o' them rare ones only found on Ebay:thumbsup::p;)
Be interested to see what makes it beyond repair, they aren't that complicated. Making it a dummy beats putting it in a junkyard scene though and leaves it for a possible repair later on.
A lot of missing parts
This engine had a life of hard work almost everyday at the hands of a teenager. Me over 30 years ago.
That is all there is. A lot of missing parts.
John
Soo what is the brand? Yardbird trains will carry a 6 wheel truck for the tender. Still don't know what the engine looks like? Looks like a can motor fitted in.
Thay are both Riverrossie (SP?) I think. the top one is working. If you think that parts are out there I will have to change my plans to make it a dummy and make it a power unit agian. The motor was mounted in the cab. There are other things on my layout that need to get done before repairing this engine. It is great to here there is hope. When the time comes I will dismatle the working on and figure out wath all is missing.
Discussion Starter #12
Just took another look. "Riverrossi Made in Italy 7713" at the front.
"Riverrossi Made in Italy BREVETTATO" at the rear.
Start your google engine and research the co. I have a Blue Goose made by them back in the eighties. Motors are not always unique to engines but onky by companies. So a motor from a cheeper loco may fit your project. Parts is the key buy used or find a dependable supplier. A diagram sheet would be great.
Keep us posted.
http://k4-pacific.com/rivarossi.html
http://www.steamlocomotive.com/model/HO-steam.php#rivarossi
http://www.golfmanorhobbies.com/pages/specialties.html
Found these at a forum post.
Oh, yeah, you're missing everything...gear towers and motor, pilot and trailing trucks just for starters...you musta hadda blast when you were young:D:D:D
Discussion Starter #16 (Edited)
The Bridge is in Place
The first train drove to the top of the raised track tonight. The grade terned out to be 3.5. Not all of my trains can make it unassisted, others have no trouble.
1 - 16 of 16 Posts
