Good day all!
I am going to be building my first layout and I need some help. I work at a Home Hardware so have access to most everything I need to build the base for it.
I have built a few things before including 4 work benches, but I thought I would post here to get some opinions on it.
The main part is going to be 11 feet long by 28-32 inches wide and then another section along the other wall will be attached to it and will be 5-6 feet long by 32 inches wide.
I was going to build this all using 2x4's, but looking at pictures, it looks like most people are just using 1x4 and 1x6 boards, but it is hard to find decent pictures for the shelf type that I am making. I am always wondering for the top if I should use just standard FIR plywood or Good 1 side FIR (one side has been sanded). I was going to go with 1/2" thickness for the top. I was going to make it 40-42 inches tall as the top of the shelf already on my wall that I am going to add two tracks on and use as a storage yard is 48 inches from the floor.
I was also thinking that the main outside frame I would make out of 1x6 and then the support members would be of 1x4. How would you recommend doing the legs and how far apart should I space them?
Thank you everyone for all the help
