1 - 18 of 18 Posts
I have a 44 ton center cab Leigh Valley diesel, basic model, and it has a buzzing sound that's very loud and annoying and I was wondering how to get rid of such sound. I believe its a contact on the E-Unit that's causing the problem.
Any help would be much appreciated!
Is it always buzzing or just when you put it in neutral to change direction?
These were kind of loud normally.
That buzz is normal.
Mine does it, it is quite loud.
Wait till someone else chimes in, maybe an electronic e unit would work?
No possible way to fix it? At all? It ruins the "Horn on the siding" actions
You are hearing the 60 cycle buzz of the e unit.
There is a way to fix it. Convert your layout to DC. I did it with my 1033 transformers.
It is beyond the scope of the forum, I believe, to instruct you how to do it. You can also convert the loco to DC. Both techniques require a bridge rectifier.
One advantage is accessories which use a solenoid, will be quiet. However, accessories using the coil and drive washer, like the rotating beacon, won't work.
All of my knowlege comes from trial and error and a gent who sold me rectifiers at an inflated price. I suggest you buddy up with an EE.
So trains don't run in DC as it is? Excuse my ignorance, I am trying to get into the wiring and repair aspect of the hobby.
You can install a bridge rectifier inside the loco to convert the 60 Hz AC from the track to DC. You will also need to add a capacitor to smooth out the full wave rectified DC from the bridge. Then, you will also need to drop the DC voltage to a lower lever so you don't cook the coil in the E unit. If you don't know about RMS AC and rectified DC, you might need to educate youself before you do this project.
Would an electronic e unit work?
The buzz sound has been around over 75 years since the introduction of the e-unit. It's part of the charm of operating PW Lionel trains.
You can eliminate it with a bridge rectifier or replacing the mechanical e-unit with an electronic one. You can buy a Williams 44-toner for not too much these days. They are excellent copies of the Lionel PW design and use all electronic controls so no buzz.
Discussion Starter #13
So is that the only way to stop a buzzing E-unit? I'd rather keep it A/C, I just want to stop the noise or quiet it down a lot
Discussion Starter #15
I'm starting to think if I am going to buy just the board I may as well buy a new 44 ton'er for 100 bucks that comes with the board, headlight, and horn. Hmmmmmm, debates man.
How much do you want for the Lehigh Valley?
What kind of shape is it in?
Is it the #625 or #627?
1 - 18 of 18 Posts
