1 - 3 of 3 Posts
Before I install a new (first) BXP88...
I noticed in the BXP88 doc (pic pg 7) it shows rail A as common. I read in the doc (note after 5.0.6 pg 6) that rails A and B must be consistent.
Having struggled with Digitrax documentation in the past, I checked the BDL168 doc to confirm this "consistency". Curiously, I find the direct home wiring pic (pg 6) shows rail B as common.
So - if I follow the digitrax installation pictures from their docs, will I have the polarity problem they warn about? I'm already running with a BDL168 wired as shown in its respective doc.
Thanks
Keith
I think the objective is to establish a common rail (period). Call it rail A, Rail B, rail 1, rail 2 or whatever as long as it is separate from the other rail over the entire layout.
You might need to be consistent over the whole layout with what is the common rail and a BXPA1 on the reverse loops. I'm thinking that you would run into problems crossing from an area controlled by 1 BXP88 to another BXP88. Be nice to know all this for sure before I install my BXP88's also Kieth!
1 - 3 of 3 Posts
