381 - 400 of 433 Posts
Sound like decal bonder is a key ingredient. I will get some along with some other paper. Thanks for the tips.
Pete
.... Inkjets are better for dark colors, yellows and lighter colors are not saturated enough. A higher end printer might do better. ...
James
I presume you realize their are settings to control the amount of ink laid down by the printer (paper type, print quality, etc.).
Well one positive for me is I got my old Hudson working yesterday. I had another old steam engine with a missing front dome plate and I took a screw out of one of its drivers. Not sure if it’s going to hold in the broken bushing, but it is working at least now. Ran it all day today.
554192
554193
Fedex office/print stores will print decal sheets. They require decal film for laser jet printers. The high end printers they use are better than home printers. Be forewarned-it’s not cheap, but if you have an original, hard to find decal or sheet, such as many old Microscale sets that are irreplaceable, you can get a “copy” to use and keep the original. In my case, I needed several sets.
Microsol used to sell liquid decal Film. It prevenTed old decals from coming apart when wet. Works perfect on home made decals Too. I still use it, apply with a brush or air brush to decal sheets.
Discussion Starter · #385 ·
86T, the decal idea sounds interesting. I am looking for Erie O scale steam engine decals. They are made in HO but not O. I am thinking they could be scaled up from the Microscale HO set. Would the printer, FedEx need a true color copy to work from or could they use black and white diagrams and print the proper color for the decals? In this case it would be a deep yellow...
I’ve been using K4 decals for freight cars. Some are great but some are a bit thin and not quite opaque. I did this Erie 40’ boxcar repainted from a MTH Premier York commemorative car. The decals were a bit thin and the car ended up having a pre-weathered appearance...
Tom
555406
K,
A true color copy would work best. If black and white, they’d need to do some experimenting-They can match any color shade if you have an example or original.
in my case, I just wanted a copy of an original so they scanned and printed it.
I picked up my 4th MTH Premier Santa Fe 3460 class Hudson back in October. It was mint but missing boards and the motor. All wiring was there. I installed a ball bearing, rare earth magnet, 9234 Pittman. I tracked down a set of PS3 boiler and tender boards and installed them today. It's fully functional and runs very well.
Lou,
Your work is always impressive, great job once again!
Thanks. That was my last non-functional locomotive, so I'm currently out of projects at this time. I did 6 locomotives this past year, so I think I'll slow down a bit. I'll pick up something else to fix or modify this year at some point though more than likely.
Cough, cough, cough.....does it smoke? (y):giggle:
Latest project was a motor swap on my brand new (2019) Legacy ATSF Northern. These have a tendency to nuke the smoke units because of a improperly placed thermistor. While I was in the locomotive correcting the position of the thermistor on both smoke units I decided to further void the warranty by removing the crappy Canon motor and replacing it with a Pittman 9433. All my Premier steam locomotives have Pittman motors (9234 or 9434s) so I wanted to make the motor in this Legacy Northern at least as good. Runs great as well.
556442
Discussion Starter · #392 ·
A couple new repaint projects I just completed. Both are Weaver cars stripped and repainted with Scalecoat II paint. They are decaled with K4 decal sets. I added metal trucks and couplers in addition to interior weights, so they are nicely weighted...
Tom
559305
559306
Beautiful work again Tom. Looks like K4 is expanding their line. What did you use to strip the Weaver cars?
Pete
Discussion Starter · #394 · (Edited)
Thanks Pete.
I used 70% isopropyl alcohol On the steel car. It was painted for some weird Christmas/radio DJ scheme. I picked up four of them for $20. No trucks, but they stripped easily.
The wood car was undecorated to begin with.
I am corresponding with K-4 now about doing some Arcade and Attica decals. We are looking into doing an A&A 40‘ Boxcar in the later baby blue scheme...
Tom
Discussion Starter · #395 ·
Car shop is busy.
Doing a 40’ steel boxcar and a 40’ outside braced boxcar…decals next.
Stripping a gondola that will eventually be a WAG car if I can get the decals to fit.
The Cambria and Indiana hopper is waiting for a dull coat finish and then reassembly.
Tom
559471
Nice work Tom. I've also used the K4 decals. My experience s that their decals need to be applied to a gloss surface-I tried applying them to a satin surface and they didn't look to good as they had the silvery background. Another company that has decals I've used with good results is CMR Products. They have quite a variety including more modern RR roadnames.
A question. When using the Scalecoat paint, are you using their primer first before applying the color coat?
Discussion Starter · #397 ·
Hi Nick.
I give the cars a coat of gloss finish before I decal with K4 products. It seems to get rid of the silvering. The satin finish of the Scalecoat paint is iffy when applying decals. I also use Walthers Solvaset. Even applying decals to the satin finish, I use the Solvaset under the decal when I apply it. I have had good results with that.
I started using Tamiya grey primer on my projects. It makes a big difference, giving a uniform finish to the plastic before applying the Scalecoat II.
I used CMR a decals on my locomotives, mainly my Bethlehem Steel railroad repaints. They are good decals too. They offer roads K4 doesn’t sell. I also use Tichy but they can be a bit temperamental and require a bit of effort to get the looking good.
Tom
Just looked at CMR for the first time. Impressive what they have for the (local to me) roads. I was surprised to see they also do Union Pacific. When I was looking for decals for my FEF I was told by two custom makers that UP licensing requirements were a hassle they didn’t want to deal with.
Pete
Good Morning Tom,
Thanks for the info. I also use the Solvaset for getting the decals to settle into place. I'll try the Tamiya primer on a couple of undecorated Weaver hoppers I'll be custom painting/lettering in the future.
Discussion Starter · #400 ·
Nick,
I do encounter difficulties now and then. I am figuring that I need to use Tamyia primer with Scalecoat II paint and Scalecoat II gloss coating in that order to get decals to set well.
I used some Humbrol gloss finish and started decaling a boxcar in an Ann Arbor scheme. The decals seemed to have an odd reaction to the Humbrol gloss. I am going to let them set up and then hit them with a gloss finish and see if that fixes the problem. Otherwise, I strip the car again and start over!
Tom
