1 - 20 of 30 Posts
I have to move the stack ahead on these conversions and this time I made the stack detachable to make it easier to attach the body to the chassis and refill the smoke fluid.
Engine Auto part Automotive engine part Vehicle Steam engine
Engine Auto part Automotive engine part Vehicle Gear shaper
Moving forward. She has a new light and a different smoke unit that needs a little less juice to operate. The original light mounting was shorting out so now it has '71 Olds parts, permanently mounted! Auto part Engine Automotive engine part Vehicle
Transport Locomotive Steam engine Engine Machine
Transport Vehicle Locomotive Engine Machine
Discussion Starter · #7 ·
Would love to see those linkages in operation ....
Ha ha, so would I! I didn't have enough info on them to make them functional so they are just for looks. Also part of the system is mounted to the chassis and part to the body. I'm trying to keep the two separate for ease of maintenance. It's the difference in a scale model and a working toy, compromises.
Discussion Starter · #8 ·
I decided to upgrade the pilot and bring it more in line with the prototype along with the boiler front. The headlight is mounted higher so I moved it up a tad and made the pilot from piping.
Transport Scale model Vehicle Locomotive Auto part
Discussion Starter · #11 ·
After spending an afternoon researching the Baker valve gear I may decide to tinker with it a bit and add a couple of linkages to the cross head. Most of the linkage visible is part of the reversing mechanism and it doesn't move. We'll see.
Discussion Starter · #14 ·
Thanks Mike, I forgot!
Anyhow, some pics of the re-done Baker Valve gear. I still have to re-do the reversing components but all the moving parts have been re-done and fitted along with new cross-head guides and the valve gear housings.
I was going to go with this...
Transport Auto part Vehicle Locomotive Automotive wheel system
but I decided it wasn't good enough.
Engine Auto part Automotive engine part Machine Vehicle
Transport Vehicle Auto part Locomotive Train
Discussion Starter · #15 ·
The final version of the valve gear. Finally!:rolleyes:
The only thing left of the valve gear that is Lionel's is the cross-head. It is all mounted to the chassis.
the only thing connected to the body is the reversing rod that runs to the cab. Not sure how i'm going to work around that yet.:unsure:
Transport Locomotive Vehicle Train Rolling stock
Discussion Starter · #18 ·
The old girl is back together and chugging along. She had to drag some lumber but that was what was sitting on the track. I have put one of Dallee's heavy duty electronic reversing units in her. They are larger than the lighter unit and are a bit if a fight to squeeze in.
1 - 20 of 30 Posts
