1 - 3 of 3 Posts
Instead of constructing a 5x19x7 folded dogbone, and basically using most of the available (at the moment) room in the basement, I have decided to build a 5x10 layout on casters. This will allow me to push it into a corner when not in use, but enable me to have access to all areas. The minimum radius is 22", so that should allow me to use some decent steam power. I wanted to have a variety of scenic effects as well. I have a lake, a tunnel, and some hills with a rock cut between the passing/runaround track. I have some industrial areas and a small yard with engine service area. It will also have a small town. The tunnel will enable me to "hide" a train, and I can pretend that it's taking several hours to reach its destination. Or I can just let it roundy round.
Building on a rectangle means that some tracks have to do double duty, such as the passing siding doubling as a runaround track. The time will come when I can have the whole basement, and then I can do everything just so. But for now, compromises must be made.
I'm curious, flyboy...what's the purpose of the "X" configuration in the upper right? It's your layout, of course, but it looks sort of awkward to use.
1 - 3 of 3 Posts
