Why? Derailment is one reason, too fast and oops. Not what you want to see if you have a fancy self train 7 feet above the floor. Modern throttles are nice so maybe this discussion this mute but it caught my curiosity.
For an HO application the answer is easy. Rob Paisely, in his reversing circuit section talks about diode placement along the track. The farther the engine moves the more diodes in line (between the engine and transformer)and the slower the engine. TO get fancy you can add a few in series and slow the engine for the curves. Operation voltage for HO on the track is around twelve the 1n4001 diode gives a .7 volt decrease 5 of them reduces it to a theoretical 8.5 volts. All this without playing with the throttle.
The diodes are directional So the track will work only in one direction. You will have to double up on diodes for reverse to work. Actually quadruple if you are using them for both sides of a curve . Then you feed power to the four straights for the fastest speed.
Cost wise the best way is to go ebay and get a lot. I got 50 or 100 of them.
Radio Shack is around 1.79 for two. ebay has 100 for 4.75 out of Mass. or less than 3 out of Hong Kong.
It seems more practical for a display or a shelf setup where the train is just running for display than operating on a layout.
