Tommy24 wanted to know how to set up switch indicators panel lights. When I started to construct my layout I did the same. Then I changed my mind. All of my indicator lights are at the switch position. This way I can look at the train and see if the switch is aligned correctly. Some of my indicators lights are the signal themselves. I can look at the signal and see what speed the train needs to be at. For instance if your approaching a crossover and the max speed for it is 30mph then then the signal should display Red over Green over Red (Medium Clear). Do not excess 30 mph, the next block is clear. If the crossover is rated at a slower speed then it's Red over Red over Green (Slow Clear). Do not exceed 15 mph the next block is clear. 45 mph limited clear and on and on with indications. It gives you some sense of realism without setting up blocks.
George
George
