So I've found myself coming across an old train set from my grandfather. An HO thunderbolt express. So I set it up and decide I'd like to build a train table.
So I've done a bit of research today and this is where I'm at. I have a couple questions I'm sure you guys can answer.
I have a 6'long by 4' wide gaming table. (used to be a table used for table top gaming, but it's thick plywood and will be adequate for this project.
I plan to top the table in 1inch thick foam.
I know that the track that I have is called "standard snap track". After some research I've realized I really like the Bachnam Easy Track and the Power-loc track.
Are these two types of track compatible? Could you use pieces from both and have everything work?
I also like the flex track. I figured that if I used some of this track I would just have to use some cork board or something to bring up the level of the track to match that of the easy track or power-loc track?
And lastly if I had a train set that was made by lets say...Bachmann and one by another company could they both use the different tracks and still work? I mean run all over the table with no problems.
All staying within the HO scale of course.
Thanks in advance for the help!
Cheers,
Cheers,
