The following is how I constructed crossing signals on my HO layout using readily available signals, infrared sensors, and components. I have two parallel mainline tracks which a road crosses. The tracks are close enough such
that both tracks are controlled by the same set of signals.
Parts Required
4 Osoyoo infrared obstacle avoidance sensor module
1 JTD877RP-2 HO scale railroad crossing signal 4 head & circuit board module
1 5 volt DC cell phone charger & charging cable
2 2700 ohm 1/4 watt resistor
1 1N4001 diode (any low voltage silicon diode)
1 1000uf 15 volt electrolytic capacitor
The infrared sensors (10 to a box) and crossing signal are available from Amazon. The cell phone
charger is available anywhere. If you are like me, you probably have a couple thrown into a junk
drawer. The resistors, diode, and electrolytic capacitor are available from electronic supply
houses such as Jameco and Digikey.
Two sensors are used on each track, one on each side of the road. The emitter and receiver are
bent 90 degrees so the majority of the sensor circuit board can be hidden in the bench top (I
use foam for bench top).
The left sensor is as supplied. The right sensor has the emitter and receiver bent up 90 degrees.
The rightmost circuit board is the flasher circuit board.
The following photo is the wiring diagram. The diode has a stripe on one end, denoting the cathode.
This is connected to the output terminal on the sensors. The electrolytic capacitor is polarity
sensitive--be sure the + lead is connected to the diode anode and 2700 ohm resistor. The cell
phone charger cable is cut off at the phone end. Separate the wires and identify the +5 volt and
ground wires using a voltmeter or digital multimeter. These will power the sensor boards and
One 2700 ohm resistor, the diode, and electrolytic capacitor act as a "keep alive" circuit on the sensor
output to keep it active, especially in the space between cars as they pass. Some areas of some cars
will not trigger the sensors. I gave up trying to adjust the sensor sensitivity and position for all of my
rolling stock.
The following photo shows the sensor mounting arrangement. The wires are fed through a hole punched
through the bottom of the rectangular cavity which will accept most of the sensor.
The outputs of the 4 sensors are wired together. Any activated sensor will cause the signals to alternately
flash. Each sensor has a screwdriver adjustable potentiometer to set its sensitivity. Start with all the
potentiometers set fully counterclockwise. Each sensor board has a green LED which lights when the
sensor is activated. When one sensor activates, the green LED's on the other sensor boards will
light. Since my crossing signals are at curved areas of track, the sensors are mounted in the inside of
the curves. The emitter and receiver are positioned approximately 1/4" from the center of the longest
car as it traverses the curve. I carved a rectangular hole in the foam bench top to accept the circuit
board. A hole was punched in the bottom of the opening to accept the 3 wires from the sensor. Some
experimentation with sensor height and sensitivity potentiometer setting will be required. I aim for the
centerline of emitter and receiver to be at axle height. Originally I tried the lower portion of the cars
but some dark cars with flat paint schemes and tank cars would not reliably trigger the sensors. Once
you have the first sensor adjusted, fasten it in place with RTV at the edge of the circuit board. Do not
get adhesive on the circuit board traces or components. (Don't use anything liquid such as Elmer's
glue as it will get on the traces and affect the operation of the circuit board.) Repeat the process for
each of the 3 remaining sensors. If you are installing the signals on a single track, only 2 sensors are
required---one on each side of the road to detect the train coming from each direction. I have turnouts
relatively close to the road so the sensors are placed close to the road. They can be moved farther
away from the road so the signals start flashing before the train crosses the road. The signals can be
camouflaged with lichen to simulate vegetation. I fabricated a electrical relay cabinet to hide one signal
for a change of scenery. You'll have to experiment to determine how much the emitters and receivers
can be covered.
Parts Required
rolling stock.
can be covered.
