1 - 7 of 7 Posts
I have 2 of these, both quit ringing the bell.
The first one had a broken secondary wire, re soldering got it working.
The second (coil) was totally burned up. I found the specs for it, bought some 30 gauge enameled wire on Ebay for $9.00.
600 wraps later, proper resistance (7 to 8.3 ohms). It now works!
I didn't trust the used ones available.
I'm happy!
That one i have was my fault it worked great until i burnt it out good it is so bad that he cant recoil it. He is looking for another bottom.
Make sure the train wheels are not stopped on the track trip with the transformer power on. These coils are not designed for continuous duty at 15v.
Thats how it happened my other train swent off the track a little. So i stopped everything went to fix it got side track then i smelt something burn and a few words came out and thats how i fried it. Won of those moments. Lol
Me too. After 50 years of being careful... A brain fart, must be aged related...
I have been using MRC AH101 transformers for many years to run conventional Gilbert layouts. They have a 10V fixed output, that is enough to work the bell danger signal and give a lot more margine against coil failure. The same thing can be done using the variable output of a spare Gilbert transformer. Try 12V first, then lower it to 10V if the accessory keeps working.
1 - 7 of 7 Posts
