1 - 12 of 12 Posts
DCC. DC would mean "block" the layout and setting up "power districts" to be turned on and off as necessary to prevent the Gomez Addams Affect. Can be very confusing. With DCC that is not needed. Each engine will have its own address whereby the operator controls them. MUCH simpler, but also a bit more costly.
My layout was originally going to be DC. I changed in the middle of construction. It is now a "blocked'(with power district) and DCC. I just close all of the circuits and run DCC.
LuRcH, if you decide to use DCC, you will have to convert your layout and engines to accommodate. Most DCC systems will allow one analog engine.
And the answer is......
Would my DC engians run on DCC?
I can run one analog(DC) engine one my layout at a time. Most DCC systems allow for such. I have had as many as 20 engines running on my layout at one time. This includes the switchers in the yard.
We once had an open house at our club years back. We had one DC(analog) engine running all of the time. One scenario we did was a handcar being chased by a steam engine. Kind of a comedy thing. We also used Bachman's John Bull and other real early units to show some historically important trains. These were all analog. The rest of the engines were DCC. So the answer is yes.
If you decide to use both DC and DCC, I would suggest blocking the layout. Kind of a redundancy, but gives you great flexibility and very few restrictions.
1 - 12 of 12 Posts
