I purchased a DCC ready Bachmann Spectrum2-8-0 at the train show last week. Tested the engine on DC and it worked fine. Installed a Soundtraxx Tsunami TSU-2200 decoder and speaker. That's when the fun began.
When running the engine it will randomly stall (no sound) and restart in a jerky manner. This happens at all speeds, less often when going full throttle. When not moving all sound effects work fine.
The problem that baffles me the most is when trying to use the Horn or other sound effects - the engine will stop dead and MAY come back to life after releasing the F? key.
Checked the wipers and pickups, cleaned the wheels and track, verified that all power connections are intact. Results unchanged.
DCC system is a MRC Prodigy Advance2.
I'm thinking that maybe there are not enough amps/volts going to the track to support this engine. Output on the wall adapter to the DCC system is 12V/1.6A. (Didn't get a MRC adapter with the Prodigy) This has been adequate for other locomotives. however, most are lower end models and likely don't draw a lot of power.
Advice, ideas and suggestions are welcomed and appreciated.
Thanks!
JDD
Thanks!
JDD
