I'll start by saying I'm confused. At this point I think I've read / watched so many different things I'm lost. I understand this that there are many different ways to get this done but nothing I've read has brought me to the point where I feel comfortable making a decision on how I'm going to wire up my layout. Based on what I have read I gather wiring the tracks should be separated from wiring turnouts and lights. In my previous layout I never made it that far as I had to tear it down and only went as far as a main bus with feeders to the track.
My current layout is N scale (N Scale Baltimore / Washington Rail Road | Model Train Forum). I have an NCE Power Cab and the NCE DB5 Booster which I purchased for my previous layout.
1. Although I don't plan on moving the layout I would like to to be able to take it apart and only have to disconnect one or two wires between each module.
2. My thought is run a primary bus wire (14 gauge - I don't know why I picked that but it seems like many others have) and then a sub bus (16 gauge) and then the feeder wires (22 gauge).
3. For the switches (motors) and lights I've read they should be separated and than an old power?
From an actual wiring perspective I've read on here and other places about using terminal blocks where all wires go to that block and the primary bus lines runs into the block and out of the block to the next one. Each section would have it's own block. I feel like that's a lot of wires going back to the same place and could get crazy quickly.
I've also seen people talk about running a main bus and then using the T connectors to run a feeder directly from the main bus. I did this on my previous layout and it worked out great but I'd prefer to not tap into the main bus and that also means if I have to move the layout and take it apart i'm going to have to cut my main bus.
I saw these on amazon and i'm wondering if it would work or if anyone has used them before. (XHF 50 Pcs 222-413 Conductor Combination Compact Wire Connectors 3 Port Fast Connection Terminal 28-12 AWG Suitable for Multiple Types of Wires - - Amazon.com) If I used those I would assume that I could connect a primary bus wire in there and a sub bus and have one left open. It looks like you can disconnect a wire which would work if you had to move the layout (again not that big of a concern). Has anyone used something like this? Am I thinking about this incorrectly?
Finally, how do you guys wire your lights and switch motors? I've read that some people do it directly from the primary bus and other will use an old discarded AC power supply and wire that up. I'm asking in your experience what is the best method to plan for?
I've been reading a lot about how to properly setup a turn out how to wire the motor so you can have an LED light turn green / red / etc. depending on direction and then laying out a yard and maybe I'm over complicating it for myself.
If possible, if you are making a suggestion can you please link to the material you are suggesting? my terminology when it comes to wiring / etc. is not very good.
