1 - 6 of 6 Posts
Just replace e-unit for lionel 601 Seaboard. Followed wiring from the old one. I think I got it right. Tried it and the engine is dead. No power. Don't know what happened. I do not see any loose wires anywhere else. Did I miss something.
Traditional e-unit, or an electronic one?
Double check the wiring. E-unit should "flip" current flow through either: (a) the field coil, with the armature-to-ground further downstream, or (b) the armature, with the field coil to ground downstream.
If a traditional e-unit, is the plunger going up and down with power cycles? Drum rotating? Etc.
vinsk, you indicate "the engine is dead". By that I am assuming you do not hear any humming noise, there is no light, nothing. If that is true, I would suspect power from the center rail is not getting to the "E" unit and therefore is not being distributed to the motor and lamp.
Here is a wiring schematic copied from my Greenberg Repair Manual that may help in troubleshooting.
Please post back on how you are faring.
swede
Replace the reverse unit parts and the motor has no response normally means a finger is not touching the drum and the connection is broken. Always bend the fingers slightly when assembling the unit with new parts.
1 - 6 of 6 Posts
