41 - 48 of 48 Posts
Discussion Starter · #41 ·
I tooked the 492 shell off and looked at the date i was wrong it is april of 1958 the 490 is clear as day. I have jewelers light with a big magnifine glass. Does the speaker sound always on when it running i thought you had to have the button part. Thanks
Al
The 492 is equipped with both the Diesel Horn feature and the Diesel Roar feature. The horn requires a special control box plus a rewiring of the power connections to the track. You are hearing the Diesel Roar which is always on, it simulates the sound of a diesel engine. There should be an on-off switch for it on the chassis.
For info, engines with the Diesel Horn can only be run with transformers that output a pure sine wave, such as original Gilbert or Lionel transformers. If a modern transformer is used the Diesel Horn will sound continuously because of the harmonics in the output power to the track.
If you want to stop the diesel roar just unsolder the black wire coming from the vibrator where it connects to the speaker terminal.
41 - 48 of 48 Posts
