I have an easy trick to extend the life of your digitrax command station and Boosters.
As a lot of you know heat or excessive heat build up in electronics is a bad thing! Adding a fan to help dissipate heat is smart and very cost effective.
I just used a 3" computer fan to blow air across the heat sink on the command station, It can have an independent power supply or jump it off of the input supply if you using close to 12 volts DC as your input supply voltage. I run my Digitrax Command station and boosters off of a 28 Volt 20 amp supply so my fan runs off it's own supply.
