Digitrax Power Supply...
7.9K views 39 replies 11 participants last post by  I Am Fasha
#1 ·
I have a new Digitrax Super Empire Builder Xtra and I am looking for a GOOD power supply for the unit. Is the Digitrax PS2012 20 Amp Power supply overkill for the unit?
The PS514 70W Universal AC Power Supply is the other option but in order to successfully imput the wires into the Command station, you have to cut and strip the wires of the power supply unit(which seems like a REALLY bad idea).
I don't plan on running ton's of loco's at once, but I want to avoid having power issues in the long run.
Opinions?
#2 ·
20 amps is a lot of power. If you're going to only run one or two, or
even 4 locos at the same time you wouldn't need additional power.
Exception: If your locos are all sound. They soak up more power
and that changes the equasion.
I regularly run 4 and up to 6 locos at the same time (3-2 loco consists)
using the basic power block that came with my Bachmann EZ DCC controller.
I think it's 2 amps. It doesn't even get hot.
#3 ·
The Digitrax Super Empire Builder uses the DB150 command station which has a 5 Amp max output. So if you never expand with more booster then a 20Amp PS is a bit over kill. This PS would be good if you were to expand to 4 DB150s and be running up to 80 locos at once.
I would recommend a 7 or 8 Amp PS for running just a DB150. You do want a little extra current from the PS for two reasons:
1- you want the DB150 to do the current limiting when there is short circuit, not the PS.
2- you don't want the PS to be running at its max current.
There are many 7-8 Amp PS's available that would work. Just be sure the output Voltage is correct, HO needs 15-16 Volts.
The Digitrax PS514 would be ok and they do recommend it for the DB150.
It does come with adapters for the DB150:
Use the BLUE adapter plug to connect to the provided 2 wire cable for the DCS100 and DB150 Command Station/Boosters.
#4 ·
I have a question about the same thing. Over the weekend I picked up a used Digitrax Chief II system. With the help of a friend, we swapped out my equipment with his equipment and did test to see if all pieces worked, and they did.
I do not have a layout but a test track I would like to use for DCC operations.
I have heard that a simple traditional DC transformer can be used to provided power to the Command Station. My command station is a DCS 100.
After reading the quick start up instructions, I need some help with a few questions.
1. Will a traditional transformer work for a power supply?
2. Do I run the power supply from the DC transformer from the connections for the track or from the accessory connections?
3. If from the track connections, does it matter on the DSC100 (which has two "power in" slots) which slot I use for the red wire and the black wire? The handbook did not specify.
4. If from the track connections, do I give this DC transformer "full throttle" or do I need to use a meter and give the transformer small amounts of power until I reach a certain amount? It so, what amount of output power?
5. Do I need AC or DC power for the command station?
#5 ·
DCS100 requirements...
Max input:20V RMS AC or 28V DC
Min input:12V AC or 12V DC
Optimal input: 5 amps AC or DC
Traditional transformer not recommended as they lack the amps. output for a DCS100.They can be used with care (voltage monitoring important) but ARE IN NO WAY A DEPENDABLE power source for DCC.
The DCS100's power "slots" aren't polarity sensitive,even with DC.
#6 ·
Thanks for the reply and the info Jake!
Let me ask a followup question, and again, thanks for the time to answer these for me :appl:
Im going to attach two pics to this. The first is a old Tyco transformer that I have, that if, Im understanding what Im reading correctly, I think this would work for a PS to the Command station, what do you think?
The second is a pic of a meter hooked up to the transformer with it at full throttle. Again if Im looking at this correctly, the numbers are good. Would you agree?
Keep in mind, Im not running a layout, just a program track right now.
#8 ·
Thanks for the reply Jerry! For my general fund of knowledge, on the display, which line of numbers am I looking at to see what you are seeing?
#11 ·
Your meter shows about 17V on the 0-50V scale but this is a "no load" voltage.If you connect a load to it (even one amp.),you'll see that voltage drop substantially.The required voltage stipulated is indeed important but you need a device that has enough punch to retain this voltage under load,thus the amperage (or wattage) requirements that are also stipulated for any specific use.
I have a regulated 13.8VDC/10 amps power supply for both my DCS100/200 command stations (used as boosters) and this is plenty overkill.Theoretically,the layout could draw up to 13 amps but in real life,I'll never have more than three N scale trains running at the same time.Potentially three amps at most (even with sounds) so I have a big margin.
For your test track,a wall transfo of 14-15V/2A will do the job,but keep in mind that your DCS100 can supply more than double this.A 14V/5A power supply would be much better.
#12 ·
Thanks for the reply Brakeman! So, this transformer will not do the job, right?
#16 ·
No...the transfo shown sends 25VAC wich exceeds the DCS100's max. input.
And yes,the DCS100 would work just fine on a 12VDC car battery though 14V is preferable for HO.The 18V idea would be great,that is if you can still find 6V car batteries.You'd also need to rig chargers in series (12V+6V) or charge the two batteries separately...small car battery chargers deliver 12V or 6V...not 18V.
However,you'd need to make an extension (easy) so that the battery remains outside the house.Believe me...you don't want a car battery in your house.While recharging,car batteries emit nasty acid vapors.....
#18 ·
Jake thanks for the info you are providing here, it is helping down the path of knowledge. This may seem crazy, but what about hooking a battery charger to wires and then to the Command Station? Save a 6 volt or 12 volt charger...
#20 ·
Thanks for the reply sir! The more I look into this, the more I'm realizing, that at this point, trying to save money, should not be the priority. The priority in this situation should be getting a dependable safe power source.
#23 ·
The PS2012 is obviously the Cadillac but...a good ol Chevy will get you to work too.Very potent power supplies can be found for less than half the price...shop around a little.
What I feel is ideal for your use...
13.5-15V regulated DC...the DCS100 can handle up to 28VDC but wastes the extra voltage through its rear heat sink blades.No point in creating useless heat.
5 amps...to be able to use the DCS100's full potential eventually,extra amps if you wish to power other accessories with it.
Ideally,the power supply has its own fuse (circuit protected stipulated).And it's a good idea to have spare fuses on hand.
With such a power supply,you'd be able to power a substantial layout safely and reliably for years.
#24 ·
The "Chevy" you discribe above, is this something that I could find at a radio shack?
#28 ·
Thanks guys! Im learning!! I cant wait to run some trains with this thing. I dont have a layout, just getting into installing decoders and programming them. Again thanks for all the help! :appl:
