1 - 6 of 6 Posts
I've had a few engines with drive wheel rim separation. I usually just squirt instant glue in them and hold em in place, (I don't take them apart because I don't have wheel-pulling tool). However, I know this is wrong! I just read a message that said JB Weld works good. I've got a nice 332 that I want to fix right, what is the standard fix for this issue?
If the tire just came loose from the white insulator and everthing is in good shape I just put a couple drops of superglue on it and pull the tire back into place. Works fine for me. Never had one come loose a second time.
AmFlyer is correct, CA, (super glue), is the way to go. I've used this method for years, as well as others, and it works.. If I have the chassis stripped down, including wheels, I use JB Weld.. You mentioned that you don't have the proper tool to pull the wheel, you don't need a "proper" tool, just 2 screwdrivers will do the trick, one on each side of the wheel. That's not the issue however; the real issue is getting the wheel sets re-quartered.. It can be difficult, especially with a 332.
Thanks guys, I’ll continue using Super Glue then.
Re. Quartering, I presume there is another discussion on this and will look for it.
And, thanks FlyerNut for suggesting the double screwdriver trick for wheel removal, (shoulda thought of this myself...).
Flyernut is the expert on repairs. We have a sticky in the S gauge forum done by flyernut on quartering.
1 - 6 of 6 Posts
