Weldwood Dry cement
Greetings all,
Has anyone tried using Dry Adhesive for gluing down your ballast instead of a 50/50 glue mix?
http://www.midwestmodelrr.com/ballasting-dry-adhesive/
If you have, any luck?
SantaFeKid1;
Yes, many years back I did use dry adhesive for ballasting track. It was not the kind in your attachment though. Weldwood brand, dry powdered glue is a very strong adhesive normally used in woodworking. It did a good job of holding ballast down too. I mixed the Weldwood in with the ballast, spread the ballast out normally, and sprayed with plain water and a single drop of liquid Joy dish washing liquid. The joy, dawn, etc. breaks the surface tension of the water and allows it to flow better throughout the ballast. All in all it worked fine. I think the Weldwood would also be cheaper, than the stuff you're looking at.
On the down side; Weldwood is very strong, and permanent. So if you ever wanted to remove it, you'd likely destroy the track in the process. Also, as CTValley says, it won't be any easier to ballast dry, than with traditional white glue and water.
The white glue is the cheapest way I know. The white glue is also removable, by soaking, and will allow the track to be removed intact.
Regards;
