Q: "I want to know if non DCC engines will run on E-Z command"
A:Yes. But be carefull, DCC uses a higher voltage and it is possible to burn out
the non-DCC motor
Q:"I want to know if I can change my command controller after a while too."
A: Yes, you can use any DCC controller you want. The EZ is just a simple and
very basic introductory model.
Q:"What engines types run and do not run on E-Z Command?"
A: Just about any DCC equiped loco should work.
IF you you have Cable or DSL, here are some videos made by Bachmann about
EZ command to get you started.
Part I
http://www.youtube.com/watch?v=JAin_nEMHlY
Part II
http://www.youtube.com/watch?v=Kj-03Lrh3EU
Just remember that Rome was not built in a day.
