1 - 6 of 6 Posts
I have tried thinning Emers glue with a couple of drops of Dawn dishwashing liquid, but I cannot get this stuff thinned out enough to go through a pump sprayer without it clogging before even the first pump stroke.
I don't know what I used 30 years ago, but whatever it was it worked fine. Now I can't find a sprayer that will discharge this mixture.
I was at Chinamart today and found an adhesive I had never heard of before, E6000. And it was in a pump spray bottle.
I tried a few pumps in the store and was satisfied this would work.
And how. This mist it pumps out is so fine it looks like a cloud of smoke. It's also not overpowering so it blows the ballast or turf from the roadbed or sub-roadbed.
It immediately soaked right into the ballast with no surface tension at all. The mist is so light I couldn't even tell I had also sprayed it onto the grassy areas next to the tracks. No discoloration with the application.
It wasn't cheap at almost $9 a bottle, but I would have payed that much for the bottle alone just to have a decent sprayer for ballast and scenery glue.
I'm thoroughly impressed with this stuff. I wish I had known about it a year ago.
I use an old bottle with a small tip, just let it dribble out ... I also use -mostly- sand for ballast, it's a bit heavier, so it doesn't move around much at all ..
This is a lot nicer and faster than letting it dribble out of a bottle tip.
If you are still working on scenery, I would definitely give this stuff a try.
I -think- I've finished the scenery about six years ago now ... I used DAP alex tube glue [ thinned with alcohol, and a bit of soap] in the squeeze bottle, hoping that the little bit of give would allow reduced noise levels , but didn't make a 'check strip' to test this .. but it is fairly quiet ...
Quiet enough that the increased noise from an old Heisler is noticeable, lol, most [but not all] locos are geared steam jobs .. shays long and short, heislers, climaxes, and a couple of 0-6-0, and 4-4-0 s .. no diesels at all in 1890, although there are some new ones in the display cabinet ..
I've had good luck using an old tacky glue bottle to dribble diluted matte medium, but that technique is a lot of working you have a large area to cover.
I may try some of this stuff. Thanks for the tip.
1 - 6 of 6 Posts
