I have what I believe to be an early Proto 2000 GP9 with Factory Installed sound. It has been running well - a favorite of mine. But now it has a problem that has me puzzled.
The decoder and sound system responds to all expected functions - the lights work, the bell rings, the whistle blows, and other sounds work as expected. But when you open the throttle, the loco doesn't move. The sounds for the diesel speeds up as appropriate, but nothing moves.
I did a little diagnostic work - removed the shell, and all seems ok - no loose wires. The motor turns easily. I checked the basic CVs and don't see anything unusual, but I don't have any documentation of what should be there. Is there an way to reset the decoder to the factory settings?
Does anyone have a suggestion as to what the problem might be?
Thanks in advance.
Thanks in advance.
