1 - 10 of 10 Posts
Hi
While shopping at Wally World I discovered this Elmers clear glue so I picked up a bottle of it to try for scenery on my switching layout. I ran a strip down the middle of a piece of cardboard and spread it with a small glue brush and sprinkled on some woodland scenics turf grass lightly and let it dry. I found it much easier to spread than the white glue and it held the grass perfectly. That is gonna be use again for sure
Bill
Never heard of the clear glue before. I just tried to look up the difference between the white glue and the clear glue. Almost everything I got (including the Elmer’s web site) had something to do with making slime.
where is a good place to obtain a kitchen scale?
I have to weigh down my rolling stock to meet the NMRA weight
to length standards for rolling stock
Thank you in advance!
Regards,tr1
Except that you may not want a kitchen scale. Often, they are only accurate to within 1/2 oz.
Try a postal scale instead. Same price range, same places to purchase.
Epoxy lenses
Elmer's glue that dries clear. Sounds like that would be a good way to attempt to make diesel headlight lenses:dunno:
regards,
tr1
tr1;
Epoxy makes excellent lenses that are waterproof and perfectly clear. I made the lenses in this N-scale scratchbuilt semaphore from 5 min. epoxy stained with Tamiya's clear red, green, & yellow model paints. The green and yellow lenses are just visible at the upper right of the semaphore. The red lens is hidden behind the lamp housing.
regards;
Scale model Miniature House
Better view of semaphore lenses
regards,
tr1
tr1;
This (unfortunately overexposed) view of the semaphore, from the other side, shows the red, yellow, and green, epoxy lenses better.
Vehicle Wood Miniature
1 - 10 of 10 Posts
