1 - 7 of 7 Posts
I just purchased this on line and dont understqand how to make it work. Can someone tell me what I need to use this item? How to wire it up?
"Flickering Fire Mini Lighting Effect Circuit w/LED (6-16V) from Faller." Try a 9V battery or a 12vdc supply,
Apparently it does not need a resistor, but you can check its resistance (and polarity) easy enough with
your VOM. If you don't have one, get one. You're gonna need it, I promise.
I will try the 9 volt
The 9 volt worked. A little disappointed in the brightness of the lights. Don't think it is going to light up a house and make it look like it's on fire like the adds show. They must be using a lot of them
1 - 7 of 7 Posts
