1 - 20 of 31 Posts
Fast track Question: my platform is a 4x8 sheet of plywood. I am using Lionel fast track. To make 2 ovals on the 4x8 sheet of plywood what size curves are need for outside and inside oval. Thanks.
Bull, I showed you the anyrail picture and the curves required to do that. You can download anyrail and use it for free for up to 50 pieces of track. It has the fastrack in a liabrary and you can test it for yourself and experiment with various patterns.
A good question.
The inner loop would be 8, 36 in radius curves. That is at the ends with 10 inch track joining( maybe four with a total of 8). After that it is decision time. Stay with 8 more 36 in curves or go the next size up to 42?. It may be impossible to do it under four feet.
I found one plan on an image search that sold the whole deal with switches but it is 41/2 by 8
Do you want two independent loops?
I don't use fastrack but it is a basic question that maybe someone can answer.
T-man, I think you mean 18" radius curves (36" circle) and I think the next size up may be 22" (44" circle)
Also, keep in mind that if running the lionchief trains with the remote controls then the loops may need to be separate.
Lastly, the track layout in your link appears to be on a 4.5' x 8' platform if I read it correctly.
Download SCARM track planning s/w at this link. No purchase/license is needed for up to 100 pieces of track.
It has Lionel Fastrack in it's database (top left menu, "O", Fastrack) with all the available Fastrack segments including the various curve diameters. You can define your baseboard (e.g., 4x8, L, etc.) and then lay Fastrack segments. That will show you exactly what will fit, etc.
Here's my plans as an example:
Text Line Technical drawing Design Rectangle
FastTrack is FastTrack O tubular is O tubular. How about you post a picture of your layouts so the people here know exactly how to answer the questions.
Sent from my SM-G975U using Tapatalk
Thanks for the clarification on the radius.
The image was the closest to 4 by 8.
Discussion Starter · #18 ·
T-MAN nice lay out. I want to do the same thing you have. The 3 track. One outside oval and than 2 inner ovals. I just have to find out what curves would work with fast track. I already have 36” curves. 4x8 is my platform. Thanks
The inner track is 027 and the outer is O gage.
The bottom is just an L for a trolley.
1 - 20 of 31 Posts
