1 - 13 of 13 Posts
As the title says, I'm interested if there are issues (switches, etc.) between Lionel Fastrack and prewar Lionel. I'm thinking of using Fastrack for a seasonal Christmas layout on the living room carpet.
Thanks, Mike
I hear that certain pre-war and Marx stuff has issues with the flanges hitting the ties on a lot of track. I don't have any personally to see at the present time.
Makes for a rough ride in Passenger cars :) Thanks John. I'll have to test for that when the next local train show occurs.
Hobo for Life
Most of the stuff should run fine, some of the smaller locos ( the switchers mostly) dont play well with the switches. I run fasttrack around the tree, most of the other stuff ran fine.
Back when I had Fastrak, I had no problems with the half-dozen postwar Lionel locos and a limited number of postwar Lionel rolling stock I had, nor any problems with some postwar Kusan and Marx locos. Even two pre-war wind up Marx lcos ran fine. I only had four swtiches at the time but they handled them. I imagine there are a few postwar locos that might be upset by a Fastrak switch or two, but then I had some much more modern ones that don't like them, either.
My Ives and Lionel Tinplate don’t like Fastrak. It’ll run but the flanges hit every stinking tie....sounds like a blender.
Haven’t tried the manual switches I have but I wager it’ll be the same/worse.
***They also don’t like O-27 rail...again it’s a flange depth issue.
No issues on Gargraves :)
Thank you.
Hobo for Life
What trains are you running? I think that may be a better determination of what may or may not work.
Discussion Starter #10
Lionel Prewar Box cab Electric 248, 249E and 259E Locos;
Lionel Prewar 529/530 4-Wheel Passenger cars, Early and Late Versions of 610/612 Passenger Cars
Marx Prewar 4-Wheel freight cars and a Marx Postwar 666
Hobo for Life
If i recall i ran my 259e on the fast track with the cars it came with. The small ones. The marx is hard as they made a lot of models of that 666. I didnt run my marx much ( i have 2 i think).
Marx will run OK as long as they aren't the "fat tire" ones. Ran good on my Christmas layout, even through a couple of crosses and switches.
Discussion Starter #13
Thanks gents. The motor in my Marx 666 is double reduction, with smoke, but no reverse unit. It does not have fat wheels. That is, the double reduction gearing allows a smaller diameter gear on the drive wheels. But it does have a traction tire fitted to a drive wheel with a recessed groove around it's circumference. And this causes problems with the isolated rail trigger system for self tending switches - unreliable as only one wheel can conducts on that side.
1 - 13 of 13 Posts
