I've got my track 'adequately' laid. Its largely a unitrack track on pink SM type of extruded foam. Little of it is flat, most are inclines, even slight ones.
At the moment I've used silicone caulking to hold the track in position. In some places it is up to 3/4" thick. I have a bunch of tracks parallel to each other (basically double tracked). I have a gap down to the foam in between the two sets of rails. I'm debating as to what is the best method to fill that up. I initially planned to use the expanded foam, and will where the desired thickness is greater. What would you suggest for these spaces? The foam expands and can make a righteous mess, so I was wondering if plaster of paris would stick, or if there is a better idea.
Thanks
Thanks
