"Nice. Kinda like hybrid postwar engine. As i said it looks good. If i saw the right tender, I think there are 3 holes at the back of the sheel. Im dont know if the holes would accomidate them but its something to consider. If not, the top would be nice " prr1361 quote.
I started another thread on lighting my Xmas Tender. I went with a switch and a nine volt battery. The last picture is a cheat I used the lamp from behind to show it off. The holes are 1/8th with 3 mm LEDs
I am in the process of troubleshooting The capacitor had a bad solder. When it is done the green and red will alternate blinking.
I was missing a pin in the IC base. I soldered around it. RTV is drying now to hold the lights in.
This is the 41 flash rate set up. I used 330 ohm resistors since I am only using 9 volts and not 12. SO 3 LEDs, 5 resistors 1 capacitor. and the timer. Plus board, chip mount, battery holder,switch and wires. It does the trick.
