A friend of mine has a 2-8-4 Lionel engine bought last year. Runs forward only. I took it apart and found 2 slide switches inside at the rear.
Both switches were set outboard. I switched them to inboard and the engine will run for., & rev., on aternat cycles. I presume it is fixed. I only have a homemade PS which I use for HO checkout. I can disconnect the DC side and use it to check out 3-rail AC.
Does anyone know why these slide switches were put in there, and why hidden??
