1 - 10 of 10 Posts
Table Furniture Desk Wood Wood stain
Bumper Electronic instrument Musical instrument accessory Wood Automotive exterior
Wood Desk Flooring Hardwood Wood stain
A beautiful three rail Hornby Silver King set, mostly metal, from our friend, Mr. Cowger, in Florida. The wheels and skid plate show no use marks, so this should be good! I have in mind a portable demo layout for this one for model train shows. My question is should I stick with Hornby 3 rail track or venture into the Marklin early three rail track?
Well, that is exactly what I have done, tracked down the Hornby 3 rail track. People in the know kindly explained to me that the center rail pick up of the Hornby does not mix well with the Marklin stud system.
Discussion Starter · #6 · (Edited)
Well, the Hornby 3 rail track came in. A British fox hunting wagon is coming from Canada. Yup.
Probably need a longer base board so the viewers don't get sea sick. Will use a plain swath of green felt for the ground cover, add in a few vintage structures.
Going to grease her up now and see if this candle will light up.
Wood Natural material Water bottle Jewellery Metal
Font Rectangle Art Pattern Metal
Discussion Starter · #7 · (Edited)
Fired her up. She runs well, though with a bit of arcing and sparking that is calming down as the grime gets rubbed off the rails. 1 amp controller at 50% handles her well. Going to need to fasten down the track, it is a bit beat up and will derail the coaches after a few rounds around the round. Mercifully short video to follow.
A "Bright Boy" track cleaning block from Walther's does wonders for reducing the sparking. Also, a higher amp draw due to weak magnet in the motor(if not a field wound motor), or just general stiffness from lack of use will also cause excessive sparking. I am doing something similar to your portable for shows but with American OO using Lionel and Scale Craft trains.
1 - 10 of 10 Posts
