it occured to me that "i have layout" was probably wrong thread name. well it was growing long anyways so i'll start fresh. for those who will be looking the part one of my proggress is located HERE.
all the pictures i take i keep on my Fotki website. if interested take a look
allrighty.
finished gluing roadbed where i'm going o have roadbed. decided to not use roadbed for underpass line to squeeze all the vertical clearance possible. slopes took extra work but i think i got the best i could get out of them. the breaking out for bridges did not make thing easier climb slope is okish the descent one however is ungodly. had to take a hammer to a section of cast "rocks" as it wouldnt clear the cars. glued foam "retaining wall" in place
so, some more of those pictures pictures. and since its been bit time there are more then usual
the granary area. i do realise the line is deam near the edge and measures to save trains from the floor will be taken
western industry area. (not sure which one it will be)
playing with rail layout for upper portion. r18 sections right after curved peco . not ideal but should be doable with slow moving switcher. allows me to have an industry on each line. suggestions on what to do here are welcome. i tried different arangements but i just keep coming back to that dblslip.
if there is a picture i'd be doing this entire thing right now it would be that one
Bridges. notes welcome
roadbed is flush with the plaster and recessed plywood forming level transition.
climb. the middle support is visible here. drilled holes in the "rocky" wall, inserted a contraption build from hanger wire and "poured" plaster of paris. still need to give it proper shape
climb bridge upper support
descent bridge lower support. the newly blasted rocks are repalced by still pink concrete retaining wall
upper
note. coloring is obviously not final and will be revisited
allrighty.
upper
