21 - 30 of 30 Posts
Discussion Starter #21
I started to light my passenger cars today. I cut 12 SMD LEDS from the 16ft strip I bought. I glued them to the car' roof and solder on a mini connector in case I wanted to detach the roof later. I wanted to use the mini plug connector but you really don't have to use one. You cannot solder the connecting wires to the Walther's rail pick ups tabs so I had to glue them on. The spring steel they use for the pickups cannot be soldered. The car looks great all lighted up. Now 10 more to go.
George
Discussion Starter #23
Thanks Mike. I've made a change on how I connect to the Walther's passenger cars electrical pickups.
I've got 8 of my 16 Walther's passenger cars lit but I changed the method on how the strip LEDS I bought connect to the car's pickups. I decided to make push on's like you see in locomotives. They work well. I thought the lights looked a little to bright so I soldered on a 150 ohm resistor to the LED strip. The car's lights look a little bright in the below photo buts that's the camera. They look great.
George
Discussion Starter #24
Continuing on getting stuff lit I bought some goose neck lights. The lights where 10 for $6.40 free shipping. I bought 2 packs. How can you beat the price? That's 0.64 cents a light. I used them on my barrel factory & 1 of Hunts Point Market wholesale produce buildings. I do the others in the weeks to come. I also ordered some freight yard lights. 20 for $6.40 cents free shipping. I bought 40. With these prices I finally found it affordable to light my entire layout.
George
Discussion Starter #25
Continuing on around the layout lighting stuff up I had to relight the RR memorabilia dwarf signal I created a few years ago. I made a mistake of connecting it to a 12v power supply one day a blew the two dollar store flashlights I use to light the signal. I did not use any rocket science as a format to light this signal. I took out the flashlight's battery parts and soldered on 2 wires that connect to a 3 volt power supply. I also bought a dollar store green plastic school notebook, cut out 2 pieces to place in front of the flashlights to display a clear signal.
George
Discussion Starter #26
The freight yard lights I bought arrived the other day. I like the lights, 20 for $6.45 free shipping. I did not like the light base so I made my own base out of some tubbing I had left over from another project. The lights come with a clip on sign that I discarded although you could print up some Christmas decorations and clip them on for the holidays if your going to use them as street lights. The light enclosure and base are white I painted them all silver.
George
Discussion Starter #27
Continuing on getting stuff lit I bought 10 3 light yard lights for $12.99 and installed yesterday. I also added some truck freight yard lights to the Hunt's Point Market truck unloading area.
George
Discussion Starter #28
Got some signal bridges going this week. I used a Oregon Rail Supply kit for one the home boards. The signals aspects are controlled by the turn outs and crossovers. If your going to use one of the Oregon Rail Supply kits use the smallest wires possible. I found out this the hard way. To many wires no enough space in the signal mass tube.
George
21 - 30 of 30 Posts
