1 - 15 of 15 Posts
And remember...in addition to degree of grade you
must provide for an easement that gradually gains
in grade from flat to your selected slope...this to
prevent loco front coupler from plowing into ties...and
you'll need a similar easement when you get to the
top so that front loco wheels don't leave the track.
The easiest way to do this is with a length of flex track
that you let 'drape' finding it's own 'easements'.
Don is right. Especially on a short slope, the slope itself is less important than the abruptness of the transition. If you use good vertical easements, a 4% grade shouldn't be a big problem. If you can't do an easement, stick with 2% or less.
2%? It's actually 2" ever 100", but since 8' is 96", call it close enough. If you use Woodland Scenics inclines, that's actually what they use for a grade.
Thanks. I'm seeing more than 2 or 3 degrees grades it seems lately. Just wanted to check in. I can see where 3+ degree can happen too.
Not sure what you mean by "seeing more"? Do you mean people using them? It's very easy to design a track plan that includes grades of 3-4% or more, but not so easy to actually operate trains on them, unless hpyounhave a proper easement at the bottom and the top of the grade.
I have been on You Tube and saw grades that looked more than 3 degrees. Anyway, CTValleyRR just hit my point. I will need to cross lines and needed to know distances to rise so I can clear trains from hitting the tops of tunnels. Thanks guys.
1 - 15 of 15 Posts
