1 - 20 of 34 Posts
It would help with the sound echoing out using underlayment in the helix I think. Especially since the Ms would be on the other side of the sofa.
Are you going to make an engineering station like you did for your flight simulator?
thank you guys. Thanks TJ, I sure missed this :)
bottom loop track is soldered and glued. Old Athearn BB GP-38 was able to pull 7 cars with some extra load on them without slipping. hopefully this means 9-10 car single engine train is possible.
Trains in the construction zone love it! :)
Discussion Starter #14
thanks Michael
Climb to the top level is complete.
I need to do something with layout lighting.
Wiring and installing servo switch machines. It takes full range of motion of the motor to throw the switch, some springiness in the piano wire linkage holds the point to stock.
Limit switch powers the electro-frog.
Discussion Starter #16
finished building walthers bascule bridge kit. Normally I absolutely enjoy building kits, not this one though, was quite an agriveating experience for some reason. not removing parts from sprues early was really good idea. some lift mechanism parts were broken, managed to rebuild the axles and retain lifting functionality. now I need to overcome the disgust ant paint the damn thing.
bridge is on a side swing gate for entry, working on magnetic latch and contactors for power.
overall view, basically a modest 10x8
That's coming together nicely.
Very nice indeed, defiantly keeping and eye on this to see the updates
What is your elevation change you went with?
Cheers,
Joe
1 - 20 of 34 Posts
