If I connect the black straight section on the inner loop, right hand side, the track goes dead at that point. Regardless of where I make complete connection, something goes haywire. Have I created a reverse loop I've been told about? View attachment 575424
Yes you have a reverse loop. That is a very clever layout but it presents an electric obstacle for you when using traditional DC control. Too bad, because that would be a fun layout.
Let me see if I can find a folded oval layout I dreamed up a while ago.
So, am I correct in assuming, with the way I currently have things wired.... anytime I create a layout where the train can leave the station going to the left and by hook and crook, I end up coming back to the station from the same direction I left, then I have created a reverse loop. Is that a correct "rule" I can go by unless I make some modifications? If that's the case, then I can live with that.Yes you have a reverse loop. That is a very clever layout but it presents an electric obstacle for you when using traditional DC control. Too bad, because that would be a fun layout.
Here's one I was working on. Do you see any conflicts on this one?
I'm going to need all the help I can get, and this looks like a good source of info. Thanks for the tip.You need to get this book. This is my copy from eons ago. I still refer to it from time to time. CRS syndrome here. It will explain just about every question you’ve asked across all your posts. Terms and nomenclature too.
While the cover art may change from one printing to the next, the title, wording and book number will be the same. View attachment 575429
A very interesting design. It makes me half dizzy trying to follow the possibilities.
You can tell it's a reverse loop because it must come back to the same 'enabling' turnout, but this time moving in the opposite direction. If you take the arc of track at lower left, and move it all back into the middle, and make it meet at that leftmost turnout, you have accomplished the same thing, and you'll probably understand that this would be the traditional folded loop. By crossing over at the diamond, you haven't changed anything except the longer path.If I connect the black straight section on the inner loop, right hand side, the track goes dead at that point. Regardless of where I make complete connection, something goes haywire. Have I created a reverse loop I've been told about? View attachment 575424
It might be fun to see what I can come up with those limitations. Maybe see if I can devise a layout where it will be as interesting going one direction as it is the other. Then, I can just pick up the locomotive and turn it around, manually.
I've yet to address spur lines (correct term?), the ones that go out and terminate with a bumper. I've got to get past this electrical ignorance before things will begin to come together for me.... but, I'm pretty persistent. Thanks for hangin' with me.
Yep, I'm aware of the two tracks being far too close together, but I was just experimenting with different layouts. I'm just experimenting - trying to see what will work and what won't. There's a heck of a lot more to this layout business than I first anticipated.Yes, that's a reverse loop in the original post.
It's going to require that you insulate BOTH rails at the entry and exit points.
How you control things depends on whether you'll be using DC or dcc.
TIP: that "outside curve" on the right?
It's "too close" to the reverse loop. Just doesn't look quite right.
Add a little straight track to "move it to the right" a little.
Or...a wider radius curve will move "the apex" to the right.
