1 - 3 of 3 Posts
Hi--I am a retired traction modeler who would like to make a shelf layout ot something that could go on the floor(compact)--any suggstions__Thanks
HawaiiTraction;
I replied to your similar post sent a couple of days ago, in the thread you started called "Tracton Fan from Hawaii" There, I gave you some files containing lots of information on shelf layouts, and other model railroad subjects. I never got a thank you, or any other response. Did you receive the information?
A shelf layout is good, but I'm not sure what you mean by "something that could go on the floor."
Do you mean
(1) A temporary assembly of track sections right on top of the carpet or tile, like a Lionel christmas layout?
Or do you mean
(2) A conventional layout, with the track, trolley, structures, & scenery, permanently mounted on a plywood, or extruded foam. base; that lies on the floor when being used, and can be taken up and stored elsewhere?
Or something else?
I think that running on the floor would be much more difficult than running on a table. The table could have folding legs, if it needs to be stored between uses.
My own layout is a shelf one with overhead catenary. I model the Milwaukee Road in the Seattle, Washington area in the 1920s. Let me know which option you want, and I will try to help.
Traction Fan 馃檪
HawaiiTraction;
I replied to your similar post in a different section of this forum. A shelf layout is good, but I'm not sure what you mean by "something that could go on the floor." Do you mean
Or do you mean
Or something else?
My own layout is a shelf one with overhead catenary. I model the Milwaukee Road in the Seattle, Washington area in the 1920s. Let me know which option you want and I will try to help.
Traction Fan 馃檪
Thanks for your reply. I inadvertently set out another discussion.
I think you're correct about putting in a shelf layout with folding legs. I had envisioned putting a board on the floor and storing it against the bedroom wall. We'll see--sorry about the exrra discussion--HawaiiTraction
1 - 3 of 3 Posts
