Thanks for the formula for grades.An HO Mile is 66 feet.
Divide the rise by the run (length)
4.5 divided by 75" = .06 or a 6% grade.
4.5 divided by 91" = .049 or almost 5%.
"In real-life railroading there are three classes of grades; 0.8% to 1% is light grade, 1% to 1.8% is heavy grade, and anything greater than 1.8% is mountain grade."how steep are the grades on prototypes?
If you do not drop the bridge you would need to have a run of 150 inches... If you do drop the bridge it would need to be about 2.15 inches high to make your 72 inch run a 3% grade... Pick your poison, LOL...Wow that is steeper than I thought. I might have to drop the bridge. There is not much more room to leagthen the run.
When I did my layout, I measured my tallest engine/car and added 1/8"-3/16" for clearance to the bottom of the bridges. It looks authentic and I can run anything I have on the layout."In real-life railroading there are three classes of grades; 0.8% to 1% is light grade, 1% to 1.8% is heavy grade, and anything greater than 1.8% is mountain grade."
From: http://modeltrains.about.com/od/layoutconstruction/tp/track_grades.htm
Like StationMaster said though, you can get up to a 3% grade on a model train set without there being problems and without it looking unrealistic...
Well, uh, yeh. Especially when a loco can't pull 8 cars up the hill!!Can you even notice a 3 degree difference or or we all getting to be rivet counters?:sly:
And they double, triple or even quadruple head those consists and add a "pusher" or two. That would be neat on a set up, but not real practical. I think that they may even break that consist and make two trips up the hill.The Western Maryland had a 9% grade between Chaffe, WV and Vindex, MD.
