Hello there,
New member here! I've made the switch from years of HO and N as a kid to O Gauge! I've bought some used MTH Protosound 2 locomotives from a local collector thinning his collection and I'm having a few issues I know you can help me with!
Let's start with the easier issue: MTH F3 ABA Jersey Central Set. Model number 20-2483-1. I've only tried to operate the A unit as I don't have room to try the others. It's works fine however there is no smoke switch/pot on the underside of the locomotive where the manual said it should be. I've taken off the shell but could not find it! Any ideas how I turn off the smoke?
The second locomotive is a little more complicated. It's a 0-6-0 yard switcher. When I put this locomotive on the track and apply power using a Z1000 and DCS Remote Commander, nothing happens. After doing research it seems that it MIGHT be the battery (MTH 9V like battery) which I replaced and now it's charging using the MTH charger. I took it off the charger after a few hours but still nothing except a single "click" from the tender. I'm going to let it charge over night and see what happens. If it's not the battery, any idea what it could be?
***UPDATE*** - Locomotive still does not run after being charged all night.
Thanks!
J
Thanks!
J
