I have two old Bouser engins, Big Boy and Challenger. What size should the corners be to allow easy use of the layout?
Thanks
Norm
Thanks
Norm
R15 will be to tight for those locos. The lower the number the sharper the curve. My 2-6-2 can make it because the wheels are small and close together. The 0-8-0 just barely makes it, that also is a short wheelbase for and 0-8-0. The locos you have are just to long to make the R15 turn without derailing.Can anyone confirm R15, R22 says a 90 degree turn and the inches of the radius? As you suspect I am a newbie!!!!
Norm, Jenks, OK
