All,
Thanks for all of the feedback that people have given. I have determined my layout based on the layout in the YouTube video below.
Currently I have created the layout to test the grades and make sure I am happy with it.
Ultimately on the lefthand side where the original has a small station, I will have several buildings.
The questions that I am struggling with is how to make permanent the trestle and supports.
My current plan: mark the entire layout. Lay track bed on flat surfaces. On raised surfaces create structure for trestles and elevated tracks. Shape corrugated cardboard to cover trestles (like in the photo). Then use plaster sheets (Woodland Scenics) to cover the trestles and cardboard. There will be a bridge at some point that would not be covered.
Once I have finished the plaster sheets I will build out the mountains and flat areas where there will be buildings and roads (the you tube video is more rural/natural than mine).
Then I will paint and lay the track beds and finish the model.
My question is, what is the best way to provide additional support between the provided Lionel Trestle set trestles? One option would be to buy several more sets to support the cardboard. Alternatively, I have read about people using dowels and plywood? I don't have a table saw so I am limited in that way (or will go buy one
Any thoughts?
Thanks,
Andrew
[/YT]
Any thoughts?
Thanks,
Andrew
[/YT]
