Having a little extra time I reviewed The auto reverse circuit and decided it was time to update. Basically I would like to simplify it, by doing a step by step. The circuit diagram is a Rob Paisley design.
First I will build a board and then show how to use a Wall Wart to power it. A voltmeter is required to do that since the output of these devices is not always accurate.
To start you need a board.
A 12v relay, RS 275-0248
a 555 timer IC RS 276-1723
two 470k ohm resistors RS 271-1133
100uf capacitor minimum of 16 volt. I used a 35v. RS 272-1028
8 Pin Socket RS 276-1995
a minimum of two 1N4001 diodes, RS 276-1101 two to a package
More may be needed
For the track, I used two 3 amp diodes RS 276-1141
I used 6 terminal connectors 3 to a module. Not required, if you solder everything in. These are harder to find at a Radio Shack store.
RS 276 -1388 will work, four blocks with two connections, to a package.
Also if there is a problem, I prefer a private post until I am finished. It just makes for easier reading and it should not take long to do. The other thread was very popular but not that readable. Thanks for the cooperation. When I am finished I will open it up for comments.
First, I use a 5 by 7 cm board. I show the socket ,relay and the terminal blocks. Electricians normally wire a box with the load to the left. So what I will do is have the 12 supply to the top with positive at the top. The center will be the transformer feed with positive to the top. and the output to the track will be at the bottom. Since this switches, there really is no positive or negative side.
I will show all this when I make the connections.
The relay has the two pins at the top to operate it with 6 pins down below for the switching.
Link to the third thread on the reverse circuit.
More may be needed
