No, there is no track on these plans yet, but heck, I am still a few years away from even being able to start construction on this... This is a 10' by 12' layout and it will be bi-level... The layout will be made up of eighteen 2' by 3' blocks so that if I ever move I will be able to disassemble it and load it into a moving van, or two, or three
The three 2' by 2' blocks will be easily removable... There will be no track work on the two green blocks, and there will be a couple of bridges running over the river on the small white block... Also, there will be no lower level under these three blocks... That way when I remove them I will be able to walk into the center of the layout allowing me to reach everything (I have long arms
Having the 5' of space on either side of the removable section will allow me to have an O54 u-turn on the both legs of the layout... I will definitely be running O72 curves at least on the outer track of the layout (this will be one that crosses through the small white block), and this means my layout will be UP Big Boy compatible
The lower level of this layout will be nothing more than one mother of a freight yard... I want to be able to have several 15 to 20 car trains assembled under there, while my locomotives will probably be stationed on the upper level... When I want to pick up a freight consist I can just go down to the lower level and pull one up allowing me to easily mix and match locomotives with rolling stock... I will probably use a switcher or two to bring them up to the upper level...
So, from this little starting point, where may I run into trouble? Please do not crush my dreams :laugh:
EDIT: Oh yea, one more thing that I almost forgot to mention... I will probably be building some mountains in the upper right-hand corner of my layout...
