Hi,
I'm adding decals to my trains now and just wondered how much Micro Sol people use when applying to their decal after using Micro Set. I've seen some places say to use a liberal amount and then I saw one guy who dipped a Q-tip in it, squeezed out as much as he could, ran it quickly over the decal, and then used the dry end of the Q-tip to quickly wipe it away.
So the question is, do you use a liberal amount ensuring the entire decal has a thick layer on it, do you apply it liberally and then soak it up so you have a smaller amount on it, or do you use a very tiny bit and soak it up like the Q-tip guy?
So far I've been using the liberal amount and with pretty good results, but if there's a better way I'm up to trying it. Thanks!
