1 - 4 of 4 Posts
I have a reverse loop that was working and is not anymore. Trains go dead in a small section of track. I want to trace where the power/signal is dropping. My volt meter can't pick up a signal.
I have a MRC auto reverse module. Also, the Powerhouse Pro from NCE switch on the back set to "loop".
What is the best way to trace power with DCC? Or how do I tell if my MRC is out.
Try setting your meter to read AC voltage. The reading won't be accurate the DCC signal is a square wave and most meters won't give a completely accurate reading, however you should be able to get an idea where your losing power.
1 - 4 of 4 Posts
