Through no fault of my own I ended up with two Rivarossi 0-8-0 switchers (OK, one of them was my fault). These were the old versions with motors in the tenders and cast tender bases that were apparently fragile, because both bases were missing along with the motors and trucks. It’s too bad because the engines are still in good shape; one of them even has the Walschaerts valve gear on it.
I tried to remotor the nicer engine but found out I need an additional gear box to marry the can motor to the drive shaft, so that’s on hold but…last month I was at a local train shop and they had a wrecked Chattanooga Choo Choo (‘Woo Woo Chattanooga by Tyco!’) in the junk box. This type of engine has the drive in the tender and the engine is just decoration. A couple bucks later it was mine and my plan to make an engine live again was set in motion.
First I had to make the motor work, but a new brush (that cost more than the choo choo) and spring plus a brass clip to hold the broken motor together and it mostly runs after the motor warms up. Then I removed the worm gear from the engine and replaced about 2” of the weight inside the boiler with dowel. Then I added some more weight to the tender, made a new plate to screw the coupling bar between the two and replaced the couplers and it’s done.
Unfortunately I have to wait for warmer weather to repaint the tender so I can put Union Pacific decals on it (unless someone knows how to remove the paint) but otherwise it’s ready to sit on a siding as part of the snowplow train, waiting for it to snow in my basement.
Problem is, now I have a really broken Tyco Chattanooga Choo Choo engine and Rivarossi tender shell, what am I gonna do with those?
