How wide can a "shelf" be?
1 reading
1.9K views 4 replies 5 participants last post by  CTValleyRR
#1 ·
Greetings all.
So my expansion to the 4 x 8 tble will be 114 inches along a wall and into a 30 inch deep by 29 inch wide alcove. This makes me think that a shelf-style might be preferred to a free standing table benchwork.
How far off a wall can you go with a 'shelf' bench? I want to go at least 24 inches. Or going that far off the wall, would legs be better than an angle base coming off the wall?
Open to suggestions! Thanks
#4 ·
The answer depends on your height from the belt up, how you'll bend, or stand on a stepping stool and bend, and how much and of what type of scenery items (trees, utility poles, structures) that you have near where your elbows will swing. It also depends on how you want the trackage to flow. You can go very shallow, 4" and a backdrop for tangent tracks. Or, if you want wide curves in the 40" radius range, you'll need deeper benchwork at the corners if it's an L-shaped layout system. And, it also depends on how high your benchwork is.
It is often recommended that you mock it up temporarily, either on the floor using 2cm masking tape or using temporary benchwork, adjusting for height and depth to experiment.
I think the best support is any that will greatly minimize the chances of catastrophe. Often, they can be vertical 1X2 with braces, or rather heavy metal L-brackets, but they'd have to be quite robust AND anchored heavily to the studs behind them (as you'd know). Depending on the surface materials, whether better quality 11mm plywood (1/2") or particle board, you'd need fewer or more brackets to prevent sagging between them. This could add up quickly.
#5 ·
You can construct a shelf of pretty much any width, with proper bracing. The problem is going to be reach. Figure 30" is a practical limit. As mesenteria said, if your layout is lower, it's easier to bend in and get a few more inches of reach, but that causes back strain for most of us. You could also invest in a topside creeper, which would help you lean over the layout, but while that works for making scenery, it's a PITA while trying to run trains.
