1 - 20 of 35 Posts
As some may know, I've been upgrading my older TMCC N&W J class to bring it up to more Legacy-like standards. I originally installed one of Gunrunner John's chuff generators for 4 chuffs/revolution as well as a superchuffer for improved lighting and smoke functions. Eventually I had a desire to improve the slow speed performance, as Odyssey let it run slow, but not quite slow enough. An ERR cruise commander M solved that issue, but not without problems for me. I quickly got in over my head, blew up the radio board and had to send it out to Gunrunner John to work his magic. A typical ERR installation is quite simple, but Lionel used a slightly different connector configuration in this locomotive which made things difficult. Anyway, it works great now and I'm very happy with the performance of everything.
Very nice. GRJ could give the big three a run for their money.
I'm glad I was able to beat Jake's J Class into submission. I'm super pleased that Scott Mann picked up the ERR stuff, I was truly bummed when Lionel originally closed it down! I'm still fighting the Cruise Commander Lite issue, don't know why Lionel won't license that to 3rd Rail.
Discussion Starter #14
What is triggering the chuffs? I notice that they drift and are not a true four/revolution.
The chuffs are triggered by one of Gunrunner John's chuff generators, which are sold at Henning's Trains. It reads a tach strip on the motor flywheel so it's generally close to the proper chuffing, but isn't perfect as you noticed. I like it much better than the original two chuff/rev that it had prior to the upgrade though.
I believe Jake may be refering to the fact that the calibration needs to be fine tuned. Instead of 4 chuffs/rev its about 3.7.
It can be made much closer to 4 but it may take a bit of trial and error.
Pete
That could well be, when I had it in for repairs, I didn't change the calibration as I just figured that was already installed and "working". :) I just looked at his video, and you're right, looks to be around 3.7-3.8. Not hard to fix, you just have to do a re calibration.
I was referring to the sound operation for some RS4 boards where there's a different note to some of the chuffs, but that one doesn't have that anyway.
1 - 20 of 35 Posts
